Ficht Revs up at dock
jettyjock
1998 Johnson oceanrunner 115 ficht. When i first start it at dock motor revs way up. I shut it off and start same thing. After about 5 times it settles down, idles good and runs ok for rest of day, but it is sputtering, spitting ,not running smooth and has some oil/gas leaking . Some say may be throttle sensor????? any help?
seahorse5
Re: Ficht Revs up at dock
Most likely the fuel pump has a pin hole in the diaphragm and fuel is leaking into a crankcase causing the rpm's to increase.
