I'm having trouble starting my 68 Johnson 40HP and have checked fuel, tank, lines and pump...now I'm up to the carburetor. I've messed with the "low speed needle valve" a bit. I've turned in a few rotations in each direction but didn't notice anything different when I'm trying to start up. My question IS...does the low speed needle valve have ANYTHING to do with starting or is it just an adjustment to make for fuel intake when the boat is cruising at low rpm's. <br />(low speed needle valve above carb in picture)<br />
<br /><br />Next question. I took apart my fuel pump and ended up having to buy a new one..gaskets were a wreck...being a novice, should I attempt to get a carb kit and try and see if the carb is the problem with starting. (http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2485001433&category=50439) Is this any good. I did learn my lesson the first time with the pump and didn't take pictures when I disassembled it...now I have the dig. cam and will be more careful. Do ya'll think the carb cleaning is do able for a first timer like me?<br /><br />Finally, last random question. How can I check if my spark plugs are getting a good spark. Should I be able to see a spark? I'm graduating Elec. Engineering in a month but when it comes to engines/parts, I'm pretty inexperienced.<br /><br />Thanks in advance.<br />Jason
