1961 Johnson 75 hp overcharging prob.
RCRCRC3
my charging system is overcharging so much that it really loads down the motor. Can anyone tell me what might cause this? Thanks.
Yepblaze
Re: 1961 Johnson 75 hp overcharging prob.
I believe that model had an actual generator/mechanical regulator circuit. <br /><br />That being the case, I would start by checking all grounds, then looking towards the regulator.<br /><br />Beyond that, the actual test procedures escape me right now.
RCRCRC3
yep it has a stator under the flywheel, and a rectifier and voltage regulator in the control box under the transom. i just replaced the regulator. also noticed i have 12 volts in the blue wire coming from the stator going to the regulator, think thats why the old one fried.
