1978 4hp evinrude, warm start problems and nees some tlc?
bill fish
Hi all, <br />Forgive this long post, an absolute newbie in regards to 2 cycle outboard motors here. Any answers to any particular question of the many to follow are greatly appreciated! <br /><br />So, here we go... <br /><br />Background: <br /><br />My friend has an Avon Redcrest inflatable boat, 8-9 footer (like a zodiac), and it is powered by a 1978? 4hp evinrude 2 cycle, 2 cylinder outboad motor. The motor has no gears (except one of course), 2 blade plastic/composite prop, choke, and a rich/lean dial/knob (apparently used for adjusting the mixture during low/idle settings). The model number is 4806E and the serial number is E0002425. Don't have any literature for the engine. <br /><br />The engines history: <br /><br />They bought the engine second hand when it was about a year old. They then used it for 1, maybe 2 seasons up in the new england states. The boat/motor was used as dinghy for a 20 something foot sailboat, so its doubtful it accumulated many hours in that time. They then moved, and the engine sat in the attic until just a few years ago. Apparently, they put gas in it, and it cranked right up and has run fine since. Its only been run a few tens of hours every year since, and the owner guesstimates that they have accumulated between 50 and 150 hours total in addition to what the first owner put on it. And another thing, since the inflatable is soooo slow with that motor, the motor has probably spent 95 percent of its time at full power. Not sure if that is good or bad, however when I've used it on the inflatable, at least it doesnt sound to me like its over reving.... <br /><br />Now, besides a few scratches, some prop damage, and few rusty screws, the motor, wiring, and plastic stuff under the cover looks in nearly mint condition. <br /><br />The problem and questions: <br /><br />First problem. I used it for a couple of days recently and it started up on the first few pulls when cold, which is pretty good considering I have wirey "girlie" arms and am in wobbly inflatable when I'm doing it. Now, if I stopped the motor, it was pretty darn hard to start right away, EVEN if I tried starting it immediately after stopping it. The motor "throttle" has runs from idle/low to full power/fast, and there is a labled "start" position about 2/3 the full setting. It also has a choke. Now, what would be the proper procedure for an immediate start after stopping. And the procedure for after sitting say 5 to 10 minutes? <br /><br />And being in here in Florida, its almost always hot and very humid, if that matters any.... <br /><br />Now, I could get it started the longer I sat, and if I sat long enough that it was pretty cold it started again okay. And a 5 to 10 minute wait seemed to be enough to greatly increase the chances. Everytime I had shut down the engine it had been running wide open for a long period of time prior to shutting down, as it almost always is.....I'm not sure if it was some kind of heat soak problem or during the dozen or so restart attempts I managed to flood it or something... <br /><br />Now, when we came home, I decided to pull the plugs. The plug metal bodies looked pretty rusty, but amazingly they came out with barely a twist! Both of em! In hindsight, perhaps they were actually loose enough to cause loss of compression (particularly when warm and at the low rpms of a pull start?). But I could see no evidence of "blowby", not that Im sure I would recognize such a thing.... <br /><br />The plugs themselves looked pretty darn good inside. Electrodes good, tan interior ceramic interior element, and center electrodes rounded but not pitted or worn oddly. Probably the original or 2nd set of plugs the engines ever had. Now, there is a paper/plastic label on one spark plug wire that says use a champion L77J4, but the plugs IN the engine were champion QL86C. Would that caused any real problems? And the gaps in the old plugs where nearly .05 inches, which sounds kinda wide to me..... <br /><br />So, any advice/pointers on the plug situation? <br /><br />Now, looking in the engine itself through the spark plug hole, I can see a relatively thin layer of carbon "crust", but some of it can actually be flaked off the top of the piston to reveal the metal underneath, so it sounds like its pretty minor as far as 2 cycles go. Anything else I should look for in there that might be a good or bad sign of things going on? <br /><br />Wanting to give the engine some TLC, anybody have recommendations for safely decoking? the engine? Is there something that can be ran through it while running, or something I can pour in through the spark plug holes and let soak for a few days to a few weeks to clean things out? I thinking it would be nice to make sure that the piston rings are unstuck and remain that way.... <br /><br />I think the engine has been taken care of at least reasonbly well since my friends owned it, though perhaps not babied. The've used good quality 2 cycle oil and gas stabilizer additive (Stab-Bil brand fuel stabilizer), but I dont think they every really prepped it for long term storage or used the stabilizer additive at the high dosages, which it sounds like the least you should do when the gas is sitting around alot and the engine is getting used not many hours per year and goes many months between uses. <br /><br />Anybody got recommendations for a good gas additive/carb cleaner? And what to do when it gets run a few days then is put up again not to be used again for up to six months? <br /><br />And a question about oils....2 things. First, the mixture ratio is recommended at 50:1. Would there be any problems/downsides with upping that a bit to say 32:1? Sure, it would cost more to run it, but it sure would make me feel alot better about the engines longevity...Secondly, whats the BEST oil to use? Again, cost really isnt a consideration considering how little the engine is run per year and how much a major repair or new engine would cost in comparision. <br /><br />Can I compression test the engine? I have a standard car compression tester. Whats the general procedure, and what kinda numbers should I get? <br /><br />Now, the only "real" problem with the engine. The lowest part of the engine, ie the torpedo shapped part right in front of the prop. It has 2 screws for draining and filling with a oil/ lubricant. What kind/brand should I use? <br /><br />And the BAD news about that......I opened those drain plugs when I got home and about the only thing that came out was WATER! The gears probably had a coating of oil on them, but thats about it.....at least I didnt see metal flakes or other odd things come out as well.... <br /><br />How should I flush it out? And after flushing, should I just put in the recommended oil and see if it stays in there? Or should I replace the seals? Would that be hard to do? Would they be expensive or hard to get? And I take it there are 2 of em? one for the vertical shaft and one for the horizontal shaft for the prop? <br /><br />I took off the prop, and that leaves a metal shaft that has a nylon? "disk" (the thing the prop mounts on) on it that appears to be held on by a shear? pin. Can I push that pin out to inspect/replace the seal behind/under the disk, or will I have to remove the small metal plate under the disk as well? <br /><br />And would it be much work to replace the vertical shaft seal as well? <br /><br />Well, thats probably plenty of questions for now.... <br /><br />Thanks in advance for any input! <br /><br />Blll
D
DJ
Guest
Re: 1978 4hp evinrude, warm start problems and nees some tlc?
Bill,<br /><br />As far as decarbing/decoking. Read this.<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=36;t=000016 <br /><br />You can use Sea Foam (NAPA) for routine fuel additive.<br /><br />50:1 ratio is more than adequate. Use any TCW-3 rated quality outboard oil.<br /><br />The car compression tester will work fine. Open the throttle wide open and pull it through about five times per cylinder. Your readings should be within five psi of each other. You may get better readings after a decarb.<br /><br />Before you condemn the lower unit seals, replace the seals on fill/drain plug screws. Use outboard 90 weight gear lube. Don't worry about flushing it, for now. Just get some fresh lube in.<br /><br />Pull the pin, the sleeve should come off. Look for fishing line would around the prop shaft.
BF
Welcome... whew my eyes hurt! I ended up skimming by the end, but yes DJ has great advice.<br /><br />The upshot of what I got from your post is:<br /><br />1) you have a 4hp that seems to run OK, but is hard starting when warm.<br /><br />2) you had water in L.U. and who knows when it was changed last<br /><br />3) plugs may have been wrong ones, and gap suggests that they haven't been changed for a loong time.<br /><br />So, running seafoam in some gas might clear up the starting problem... it's probably got a partly clogged low speed jet, starts OK with choke, but when warm is running a bit too lean. Turning the rich/lean knob 1/8 to 1/4 turn towards rich might help too.<br /><br />Given that the motor sounds like it's been mostly neglected maintenance wise, I think you'd be wise to change the impeller. These are wear items... Also, it might be pumping poorly and thereby overheating the engine and contribute to how it runs/starts poorly when hot.<br /><br />Oh, and a service manual would be a good idea!!<br /><br />good luck.
bill fish
Thanks for the info so far DJ and BF!<br /><br />How do I remove that pin?<br /><br />Do I just use a small bolt and hammer and drive it outa the shaft so I can remove the nylon disk?<br /><br />I just tried that without tapping things too hard and it was a no go....so I sprayed some good penetrant oil on it.....<br /><br />So, HOW hard to I have to bang to drive it out? Or is there some other way/trick?<br /><br />And is replacing the impellor/water pump a very big or expensive deal? Or rebuilding the carb? Though given how nice the plugs looked, I'd rather not do anything drastic to the carb right now....<br /><br />thanks again!<br /><br />Blll
Paul Moir
Normally I would defer to any advice DJ would give you, but for that one particualiar engine a slightly stronger mix than 50:1 is a real advantage. <br />The Johnny/Rude 4hp is an excellent little engine and was produced in various forms from the early fifties (as the 3hp) to the early eighties. But it retained many of it's original design characteristics over it's lifespan including plain rather than roller connecting rod bearings, and oil slingers rather than oil seals on the crankshaft except for the top crank seal. For this reason it appreciates a little extra oil. I use about a 40:1 mixture.<br />This is more than the mixture originally specified by OMC (50:1). Other than knowing the internals of this engine and the reasons for having an extra volume of oil, Iboats member Chinewalker sites a large number of 4hp engines that have suffered connecting rod failures as a good reason to use extra oil in them. See the Oil Mix FAQ in the FAQ forum for more information.<br /><br />Running your engine at full throttle for long periods will not hurt it at all. <br /><br />The spark plug charts I have indicate a QL86C plug for your engine. If you have a nice, tan insulator showing then they must be working well. The gap should to be .030" though. The L77J4C is a hotter plug and may improve low speed operation by reducing fouling, but if the QL86C is working out for you then keep using it. <br /><br />If the engine's been sitting 5 or 10 minutes, you may need to choke it a bit to start it. But it sounds to me like you've got something wrong. Check your spark to make sure it's still strong when the engine is hot (and will not start). Failing that, a carb rebuild would be in order. <br /><br />When all is well with that engine, it ought to start in a couple pulls maximum - even with slow girley pulls. :) <br /><br />EDIT: you and BF posted while I was writing this up. <br />The pin should have been stainless steel, but if someone stuck a nail through it it may be rusted in place and tough to remove. I just went through that with my '72 4hp. If that's the case, then penetrating oil and driving the pin with a screw or similair thing is the way to go. I had to go so far as to make a little wooden cradle for the plastic prop hub so I wouldn't break anything while I hammered from the other side. Try not to hammer against the propshaft or you'll risk bending it.<br />The water pump and carburetor rebuilds are niether expensive nor particulairly difficult. Disassemble your water pump before ordering parts so you can find out if you need to get a whole new pump or just an impeller and wear-plate.<br /><br />Here's a nice site for 3/4hp tuneups. Ignore the stuff about the ignition system though - that's older model information:<br />3hp/4hp tune up
Paul Moir
Daah! Your right and I forgot. <br />They joined the rest of the world and made increasing numbers hotter plugs. And your right in thinking that I was thinking of the older small engine plugs. I was.<br />Thanks for the correction though! That's what makes places like this so good for information - we're all looking over each other's shoulders. :)
bill fish
Thanks for all the info guys!<br /><br />Okay, the original stainless steel pin was in there.....it was a bear to get out but I finally did it!<br /><br />NO fishing line wrapped around the prop seal, and from what the owner says, there probably never was....just a half a thimble full of fine seaweed/grass is all I found....<br /><br />So, I cleaned things up REALLY good, and filled (overfilled actually) the lower unit with oil. I then oriented the engine such that both seals (as far as I could figure anyway) were as below the oil level as possible, and I left the higher<br />fill hole open. Well, checking it again this morning, there was absolutely NO oil coming outa the prop seal, and I dont think any came outa the top seal......So, at least the seals arent SOOO bad the oil just runs outa them!<br /><br />Now, I understand the lower unit is supposed to seal against a fair bit of pressure as well as some vacum. I take it this occurs as the fully sealed unit heats up and cools down? So, once I get this thing back in the water, won't the real test for leaky seals be to cycle from cold to hot to cold as many times as possible, rather than just running full out for hours on end? Then, after *** cyles drain and look for water in the oil? So, for testing how many minutes should I run to fully heat up and how many minutes stopped to mostly cool down? Any guesstimates? Is there any oil additive that might recondition the seals? (which I'd only use of course should there actually be a seal problem)<br /><br /><br />As for the spark plugs. If the QL86C used so far looked good just keep using them then? Gap em at .030? And now you guys are saying those are the hotter running ones and the L77J4s (recommended) are the cooler running ones? Whats the upside/downside to hotter spark plugs? Any signs of them running tooooo hot (by the way the plugs look or how the engine runs)?. Would the fact the plugs had a gap of nearly .05 made a difference in starting or warm starting?<br /><br />I managed to also get a better look inside the cylinders last night as well....there really isnt much carbon on the piston tops.....I can see the circular honing marks on the cylinder walls, with only the faintest of vertical(ie piston travel direction) marks, and those may just be in the oil on the surface...And the wall intake exhaust ports look nice and clean as well....<br /><br />I can't go to the store for cleaners till the weekend.....is there something I can put in cylinders to soak the rings till then? WD40, plain gas, straight 2 cycle oil, standard oil/gas mix? Or perhaps some REALLY strong penetrant that I have called PCB blaster (which is rather expensive but its the best stuff I've ever used!).<br /><br />Thanks again guys!<br /><br />take care<br /><br />Blll
placebo
Billfish, You have gotten some great advice. I would advise against using very much of the PB Blaster inside the engine for fear of damaging the old seals. The stuff is good, maybe too good for this application. Some other members may have information about this being ok.<br /><br />David
