Bruce Hobart
- Jul 7, 2004
- 6
My 1988, tiller, 2cyl. manual start Evinrude will not reach maximum rpm at wide open throttle unleess the lean/air screw (needle-valve) is turned out 1/4 to 1/2 of a turn out (i.e. from in all the way);unfortunately the motor will not idle at this setting. All adjustments are correct, float setting has been done and carb completely overhauled...yet I can't find a happy medium for WOT or idle. Help guys, I getting desperate...(oh new intake gasket was installed with new carb base gasket..no vacuum leaks that I'm aware of. Thanks ahead of time for your input!
