Ever seen a motor rigged like this?
rwise
Re: Ever seen a motor rigged like this?
they could not find the correct fitting?
Walker
That's just a VRO motor without the oil line.
jsfinn
Gotchya. The owner must be mixing oil in the fuel tank.<br /><br />Thanks!
jsfinn
Er..ok..now that I think about it .. I've never used a VRO and always figured that there would be an oil reservoir under the hood. Is that not the case? Do VRO motors have a separate external gas tank and oil tank? If so, they must require a special fuel line.
angus63
Separate oil and fuel lines from separate external tanks. Mix occurs in the pump. Single fuel line requires premixing. St'd fuel line is used for oil side when used.
jsfinn
That's what I needed.<br /><br />Thanks!
