1981 Johnson 35hp lower unit
4uterry
I have changed the lower unit on my 35hp Johnson twice and they don't last. What other year model lower unit work on this motor?
D
DJ
Guest
Re: 1981 Johnson 35hp lower unit
Please explain "don't last".<br /><br />One thing that kills lower units is "easing" them into gear,<br /><br />Shifts should be quick and sure.
4uterry
I don't think easing into gear was the problem. I have talked to several other owners of this year model and they have had similar problems. These lower units manufactured around 1981 have short life spans. I am trying to find a different manufacture date that has a better life span and will fit my motor.
G DANE
I think lower units up to at least 1989 will match. As long as they are from the twin. The tripple looper has a different l/u. What breaks - I never heard of troubles and I am actually looking for some parts for one I have that ran with water.
D
DJ
Guest
OK, I'm going to be a pest here.<br /><br />What, in the assembly fails? The clutch dogs? The gears? The bearings?
4uterry
Both times the lower unit failed, when disassemblied the casing was full of broken gear teeth and the only salvageable piece was the prop shaft. I purchased a rebuilt lower unit after the first failure. I lasted about a year.
Chinewalker
Hi 4uterry, <br /> Either you're gotten a couple of bad luck lower units with defective gears, or there is someting common to the two lower units that has caused them to fail prematurely. I am not aware of any intrinsic defect in the 35hp lowers. I've seen lots of these in operations for many seasons without problems.<br /> Many things can cause gears to fail prematurely - all preventable. Maintenance is number one - take care of them and they'll take care of you. Check the lower unit oil more than once a season. Use the recommended lower unit oil for your motor. Check condition of propeller - a bent prop can set up harmonics that can stress gears. Check shift adjustments - improper shifting can lead to premature clutch dog and gear failure. Check alignment of tower/exhaust housing - a bent housing can stress the driveshaft, and by extension, the gears.<br /> You said previously purchased unit was "rebuilt" - by whom? A certified tech or a shade-tree mech? Not saying a shade-tree mech isn't a good mech, but sometimes the techs know stuff about their brand that the general wrench won't...<br /> Good luck!<br />- Scott
4uterry
I am at this time looking for replacement lower unit for my 1981 35hp Johnson, including case. If an older or newer model than the 1980-82 will work that is what I am looking for.
G DANE
Several years will work, just make shure the shift shaft is seperated inside the water istake screen like it is on yours. As mentioned I think up to 1988 will fit. I had several without experiencing ANY problems ever at all. The one I have apart now ran with water, no gearbox can.
4uterry
Will 35hp 1981 Johnson powerhead fit on 1980 25hp Johnson motor?
G DANE
Yes it does, but the loss of thru-hub exhaust will cost you around 5 HP. You need the mid section from the 25 HP as well as the Lu/midsection joint is different.
4uterry
If I install a 35hp powerhead (1981, Johnson) on a complete 1980 Johnson 25hp motor, after removing 25hp powerhead will I still lose 5hp?
G DANE
Yes - it will perform like a 25 - 30 HP.
maraxion
Sorry to hijack the thread, but it looked perfect like my engine.
My lwer unit is gone, but I can get a cheep rebuild, but im unsure how to het it loose.
Any tips or info? I guess the screws are easy, but does it have to stay in a specific gear and such?
