I just inherited a lower unit for one of my parts motors, 35 Hp Evin, which were too good to trash. Unfortunately some unknown person tried to remove a stuck propeller by breaking with two screwdrivers and broke two chuncks off lower unit housing from edge around propeller. Instead of welding I thought of sandblasting edges of alloy, sanding thickness a bit down on outher and inner and fixing the missing pieces with poly resin mixed with cut glass and a very thin layer of cloth inside and outside. Sanded and painted at last. Will this work ?? I think welding there will heat bearing carrier, and motors isnt worth a lot. Gear works fine and seals are tight.
