Re: johnson 115 more power needed
oh yes, absolutely! that is where the jack plate comes in play. if the motor is flat against the transom, and the prop is too high, you will cavitate. definately.<br /><br />with the jack plate, you not only can raise the motor higher removing more of the lower unit out of the water, but you move the motor back 4, 6, even 12 inches or more depending on type of plate used. by moving the prop/motor back, which is called the "setback", you give the prop some "cleaner" water to run in, allowing more bite and grip, this improving effiency. thus giving you more speed with the same hp, also giving you more fuel milage too.<br /><br />you can get a fixed height jack plate(non adjustable) for under 100 dollars at any westmarine.com or boatus.com<br /><br />if you need to adjust the height, you just loosen the mount bolts, slide motor up or down, and tighten bolts
