steviecops
 - Oct 3, 2003
 - 585
Hi<br />I recently bought a used OMC prop for my Johnson 55.  I went from a 17 pitch to a 15 to increase my rpm.  The replacement prop didn't have a diffuser ring fitted, so I tried to take the one off of my old prop to fit it to my new one.  The obvious happened and I broke the ring, so I made a repair with araldite and taped the ring in place while the araldite cured.<br /><br />When I took my boat out, about 500 yards from the ramp, the engine suddenly picked up by a couple of hundred rpm for no apparent reason.  When I got back in, I discovered that the diffuser ring was missing.  I'm assuming that the increase in rpm happened when my repair failed and the ring came off.  <br /><br />So, two questions.<br /><br />How do I fit a new diffuser ring without breaking it?  And will it hurt to run my engine without a diffuser ring fitted?<br /><br />The engine ran great a the higher rpm.<br /><br />Thanks <br />Steve
