Re: 1969 johnson 85 hp carburetor icing
I am a pilot and we are all familiar with this, air going thru your venturi increases in velocity and the temp drops causing ice to form until your engine is warm enough to heat the carb. Worst conditions are 40-50 degrees and humid. This is why your car has a heat risor pipe from the exhaust manifold to the air cleaner. If it is iced up shut down and wait a few minutes for the carb to warm up. My big boat has the same problems, runs great for the first 5 minutes then won't idle until fully warm.<br /><br />Dan
