Snookman54
- Oct 27, 2004
- 2
The problem is it will run out of fuel at idle I belive it does any way. You can hear the engine starting to lean out and the idel is erratic unless you pump the primer bulb then it will pick back up untill it runs out of fuel again. This engine runs great at WOT or at any RPM expect idle. This is the grocery list of repairs that have been made to solve this problem. Statring at the fuel tank pick up was removed and inspected for cracks or pluged screen, fuel lines replced from tank to primer bulb, fuel/water seperator filter replaced, spark plugs replaced installed QL78YC, carbs have been rebuilt. Hving said all that the VRO pump was replaced prior to having this idle issue because of a alarm going off, does any one think this maybe the problem? If so how can one go about checking the pump for proper opperation, is it vacumm operated I see there some wires going to it is this to power it or for the alarm? Any help would be appreciated. Thanks
