Re: 1972 85hp Johnson parts
You've got it right. If you want shifting controlled by the throttle lever, you've got to get the Johnson control. The Evinrude will work with your motor, but as you say it shifts by pushbutton. <br /><br />Be aware that there is a pre-1969 Johnson single lever control that has a rectangular plug and will NOT work with your motor. Again, you want one that has a round, black plug at the motor end of the wiring harness. The pre-1969 lower units default into neutral with no electrical current, while the 1969+ LUs default into forward - that's the difference & that's why the earlier control boxes won't work with your motor.<br /><br />Finding one is a question of how patient you can be - easy to find inexpensively if you're not in a hurry. EBay is a good place to look. In a pinch you can wire up your own.
