Hi,<br /><br />I just bought a boat with a Johnson 150 HP. The motor has 75PSI even in all pistons and it runs fine. However, after running it fast for 15 minutes, it runs out of gas. The hand pump gets all sucked in and I have to disconnect it from the intake side. It will gain it's shape and then I'm able to pump gas to the motor again. It will run for another 15 mintes and do the same. I removed the gas cap to see if when air goes into the tank it would fix the problem and nothing.<br /><br />Any ideas??
