Re: Motor cutting out when trimming up or dwn
Hello Blue...welcome to iboats.<br /><br />Does the motor cut out right as soon as the Trim switch is pushed or does the motor move then cut out? Will it restart with out moving the motor from the position it stalled in?<br /><br />Give this a shot....start the motor...don't have to be in gear, and start trimming up. If the motor stalls, look at the trim angle. Lower the motor and restart. Now, grab hold of the wire bundle going into the motor and start lifting up to approx. the trim angle the motor stalls at. If the motor stalls, the problem lays in the wire bundle where it goes into the pan. Maybe a wire rubbed bare and grounding out. And yes, go ahead and take a look for lose grounds.<br /><br />Keep us posted of anything ya' find....
