Re: 55 HP Electric Shift Evinrude '68 Lower Unit
Welcome to iboats and did you disconnect the electric shift harness? There are two rather heavy wires with the connection under black sleeves, one tagged green and one blue. Put a string on the one that goes through the motor and down to the gearcase so that it will be easy to pull back when you're done. Sounds like you have all the bolts. Four obvious ones on the sides with 9/16 heads, one large one in front of the torque tab with a 5/8 head, and one under the torque tab with (I think) another 9/16 head. The torque tab is held on with either a 3/8 or 7/16 head bolt. So there would actually be 7 including the torque tab screw.
