Re: Tips for easy starting
I agree with you Chinewalker, there's really only one way to deal with engines, and that's by being picky with them. Changing what needs to be changed and taking proper care of them. It's a circa 68 model, longshaft. I'm in Ireland so some of those products might be hard/impossible to get. I'm planning on winterising it, but I'm unsure of the correct procedure. Does anybody know where to find a 'checklist' for doing it? I've got one for the diesel in my life, but I ain't seen one for outboards.<br /><br />Ob, the problem with showing him what I do is, he's too old to be yanking my engine to get it started, so less pulling is always safer. All I do is give it full choke, pump primer hard and make sure I can't hear any air escaping from the engine (I think it's just the connection, sounds like it) then I turn it to full, since I took the throttle spring out because I'm using it with remotes, it rolls back, so goes to start. Then I take up the slack on the starting mechanism and start to yank. It takes approx 20 pulls for it to start, but it's consistant. After one day, 20 pulls, after a week, 20 pulls. my dad thought it was a good idea to make the plug gap smaller, so that it's a smaller gap to cross, made sense, but it makes better sense since we don't have a problem with spark, to make it bigger. Anybody know the correct gap? It's now 22 thousand's of an inch, was around 32.
