ranger 360
- Jan 11, 2005
- 26
I had my boat in the garage for 6 months Took out and added fresh gas to the tank.Motor is 1989 Gt 150 it starts fine and idles fine but when pushing the throttle down it dies If I push the choke at the same time while pushing the throttle it will take hold and run great. But when I come back to a idle and try again I have the same problem .So do I remove and clean carburetors and is this a job that I could do? Or is Major and needs a pro to do it.I guess I should replace the fuel filter first to see if that helps since it acts like it starving for fuel But it runs great at high speeds.need help.
