Re: Johnson 200hp Proppeller
nelson....What RPM does your 200 run at WOT now with the 15 pitch? You have to look at the prop like a gear in your car's transmission, if you were driving around at 20mph with the car in 4th gear you'd be lugging it badly and beating on the engine, and if you were running your car at 40mph in 1st gear you'd be running it too high. If you are stalling when docking it doesn't have anything to do with the prop, making the WOT RPM correct won't affect your docking.<br /><br />eula...I have a pair of 2000 200hp Johnson's on the back of my boat, with 17 pitch props, they both run at 5800 WOT and run perfect. On offshore trips they run between 5000 and WOT all day long without missing a beat, speed is about 45mph on a 25' Hydra Sport W/A, total setup is about 6000lbs, and usually have at least 4 or 5 guys on board all at 165-190, so about another 900 and then all the gear, so at least 7,000lbs fully fueled. I'd do what angus suggested and get a tach and see where your at, but I agree with walleyehed that the 17's will probably be your best bet.
