Re: Help with finding the year on a 33 H Evinrude
Yeah, there's Seloc and Clymers ones out there. Often you can get one from the local library too. They're the cheapest. Iboats sells the Seloc one - it's pretty good as far as the aftermarket manuals go. The factory ones are much better, but they're more expensive. Some times they turn up on ebay for 1/4 the price.<br />
TheOutboardWizard<br />
Mastertech<br />
Marine Engine<br />
Ken Cook <br />If you've got good compression, the engine is probably worth repairing. It would be a good idea to drain the lower unit oil and see if it's got water or metal chunks in it. The nice thing about these old OMC engines is that you can work on them pretty much without any special tools, and parts for them are cheap (as far as outboard parts go). The entire ignition system can be replaced for around $70 in parts, for example.<br /><br /><br />Hey, what luck! Check this out:<br />
Ebay Auction<br />The only thing different between the Evinrude 33 and the Johnson 33 is the cowling and paint.
