Originally posted by nautiJohn:<br /> Skipmunk;<br /><br />Two things make up boat performance, Hull design & the motor (HP). Both are equally important!<br /><br />When someone wants more performance from a small boat (20 ft. and under) they immediately go to the motor / prop. This is only half of the answer. If the hull is not efficient then the boat will never reach maximum performance.<br /><br />Trim tabs (like flaps on airplane wings) allow you to adjust the hull design, to suite the conditions of the moment. In doing so, the efficiency improves, the speed for any given engine RPM will improve (more speed from fewer revolutions), and logically the fuel consumption will go down. How much is dependent on the other conditions but over all we have recorded between 8% to 23% depending on boat speed and hull design. If you are cruising in the 16 mph to 22 MPH the improvement will be more. <br /><br />The Smart Tabs for your boat would be ST980-40 and if you decide in the future to change engines you can simply adjust them to suite the new HP and weight. Check with your local dealers or call our distributor - <br /> Telmo Controls (47-22-672360) at Rolf Hofmost Gt. 18, P.O. Box 2906 Toyen, N-0608 Oslo, Norway<br /><br />The overall performance of your boat will improve dramatically, we guarantee it!
