Re: 35 johnson 1976
Hey,fireman...thanx always for your help. I've gone off in 3 directions,sorry.For now,let's stick with tank & powerpack. I tried the gasket and it seems to seal,but while shaking the tank to test seal,I turned it upside down and fuel was pouring from the take off fitting itself.I know that up-ending it is not normal,but I was surprised it leaked.The new tank I'm looking at is a "hulk"brand and is the only 6 gal. that will fit in a limited space,but I'll check out a genuine...it makes sense. Now to the powerpack.My motor does not have one.It's a RL76S serial no:0000002- it might be a test model.My ign.coils don't have any wiring heading starboard apart from the plugs.The area behind the main cable connector is empty .No PP in sight anywhere.Could OMC not have used CD2 ignition on early motors in that series? BUT,my ign.coils have a blue plastic sheathing about 1mm.thick,that covers the centre part of the coil.It has a split in this casing which has some old silicone on it.On the other coil,there is a split at the back uncovered.Is that terminal for the coils? The wires from the top are very well sealed,so I imagine these splits are bad news. I cleaned up as much as I could,which helps in working out what goes where.Gee,I'd love to know where the hell my powerpack went.There is no sign of it ever being there......looking forward to sorting this out ,then going for a wander thru the carby.thanx again
