I have a Johnson TN 27 that I cannot get started. I have cleaned the carb and resealed the cork float, replaced the spark plugs and checked the ignition system, all to no avial. I can get it to fire a few times by pressing on the carb float valve through the hole in the top of the housing and allowing the float bowl to overfill. It will fire with this done and a fully lean mixture setting and throttle open but then dies and wont fire again with normal mixture and throttle settings. Any suggestions? I have the float set to the original position with the clip in the notch.<br /><br />Thanks, my arm is getting sore.
