My motor sometimes runs right other times not, at times it runs like it's not getting enough gas. If I bump the choke it will pick up and right like it should. Any help would be great.
Howdy, Dennis.<br /><br />Welcome to iboats. <br /><br />Look for restrictions in your fuel supply system, water in the gas, air leaks in the fuel lines.<br /><br />Another possibility is that one of your carbs has debris in the bowl that intermittently blocks the jets.<br /><br />Good luck.
Well here is an update, still having problems and have took the carbs off and cleaned them going to get new gaskets, cuz the old ones were shoot and hope that is the problem
Just get the complete carb kit Dennis. Blow out all carb passages with choke & carb cleaner and follow up with compresed air. Set the floats level with the float bowl gasket surface. Invert the carb body and eyeball the float. A smigen high on the front is OK.<br /><br />Let us know how your doing.
