Re: help with starter
Is the starter spinning at all or does nothing happen when you turn the key? If it is spinning but the flywheel is not turning, see if you can turn the bendix counter clockwise to see if it rises up to mesh with the flywheel teeth. Sometimes they stick. You also said the battery is fully charged. That does not mean its a good battery. Use a known good battery -- like the one from your car to prove the battery is not the problem.
