Re: no water coming from water discharge
Did you make sure to install the impeller with the key that fits into the shaft? Otherwise the impeller won't move.<br /><br />Also the plug maybe further into the system, and I was told by the local Johnson mechanic to blow out the lines with compressed air periodically.
