My 1990 150 johnson has a small leak under the power pack on the crankcase.The leak is about a quarter of an inch long and the only reason I saw it is because when it coughs it blows a small puff through the hole. The marina where its being looked at now says that I will blow the motor if I don't fix it...is that true? Ofcourse they'll have to split the powerhead to get to the gasket. Im being told that it's going to be $1000.00 or more in labor. That sounds like a milking. My question.... Is that a high pressure area? and can I seal that from the outside with marine tex or liquid steel?
