OMC Jet Drive- 1997
starbucks
I'm thinking of buying a 1997 15' Boston Whaler Rage. It has a 115 hp OMC jet drive with 27 hours on it; seems to be in great shape. Any advice??
JB
Re: OMC Jet Drive- 1997
Boat topic.
dajohnson53
Starbucks, based on what you've written, I'm assuming this is an OMC "inboard" type jet pump - an OMC 2 stroke powerhead coupled with a jet pump, sort of like OMC's version of today's Merc Sportjet? I know they were sold in the 90s, but I don't believe they've been made for quite a while. If I recall,they didn't have a stellar record, but I have no personal experience with them. When I was used boat shopping a few years ago, I was told that if the thing operated perfectly it could very well be a fine outfit, but it wasn't considered a strong selling point, if you know what I mean. I have no idea if they're still supported (in parts and service) by local Johnson/Evinrude dealers. You might check that out if you don't get a better response here.<br /><br />If my assumption is wrong, is this an outboard with a jet lower unit? I have one of those.
starbucks
D-<br />Thanks for your response. Right the first time--it's an "inboard" type jet. I do know that Bombardier bought them out in 1999 and I'm currently looking for that local support you advised.<br /><br />Re your boat, did you find the slippery handling hard to get used to? It's very different from a normal prop outboard. And, does yours run rough and whiny at low RPM? I was told that's typical of jet drives but I don't have enough experience with them to know...<br /><br />Thanks,<br />Starbucks
dajohnson53
I currently have an outboard Johnson with an aftermarket jet lower unit, so I'm not in the same situation as you, and can't advise you on the low RPM running. All my comments were based on second hand info/advice I was given when I was second-hand boat shopping 3 or 4 years ago.<br /><br />My friend has a current (less than 5 year old) Merc Sport jet. I haven't noticed any whiny or roughess at low RPM.<br /><br />My old V8/American Turbine rig didn't either, but that's an entirely different beast, powerplant-wise.<br /><br />But all jet boats do handle differently. They definitely tend to slide, which can be your friend as long as you know it and learn to use it. My current boat with the outboard jet, I'm very happy with. Probably because it's not a "sports car", and one doesn't tend to get into trouble with it. I think it steers better and has a better reverse than the previous inboard jet I had.<br /><br />I used to have a 19 ft. Jetcraft with a 350 chevy and jet pump. This was a pretty quick boat - actually a little overpowered, I think. That boat could get you in trouble in a hurry if you didn't constantly think about how it steered. I sideswiped the bank hard once because I didn't "pre steer" a corner (not paying attention, operator error). My brother in law hit hard dead on a corner when he panicked and cut throttle and lost complete steerage. No personal or hull damage either time, thank goodness. I'm here to tell you that Jetcraft hull (before merger/take over of/with Harborcraft) was a brick - extremely well made, well finished and tough.<br /><br />Anyway, the steering of a jet boat is something you should really school yourself with. I'd operated prop boats all my life and that self confidence did not serve me well. My brother in law, same story, same result.<br /><br />Good luck and have fun with your boat.
