Trouble shooting CD ignitions
R.Johnson
Many times on this board, the question comes up about touble shooting these systems. Sometime back, I ran across an add showing a DVA adapter, so out of curiosity I bought one. About the only way to deal with these systems is to have a peak reading volt meter. The trouble being is that they can be quite exspensive for just occasional use, and some are a special item that are good for just one thing. The adapter I bought plugs right into a low cost Sear's digital meter that I had in the shop. I checked it out on a 73 V-4 that I had on hand, sensors, charge coil, and pak. The readings were in agreement with my Steven's CD-77 meter. I am certainly not trying to push someone's product here, but this could be a good trouble shooting tool for the person who want's to make there own repairs as we have on this board. The meter, and adapter only cost's about $50. If it won't cause a conflict on this board, I can post the name, and model numbers. Plus! I want to do some further testing with this tool.
dolluper
Re: Trouble shooting CD ignitions
Hummm sounds interesting can you send me the info at my name @ gmail.com thanks dolluper
rodbolt
hello<br /> while a DVM and the DVA adapter is ok, I have one myself, it usually wont work for intermittant problems due to the response time of the meter. a DVM samples then changes the display. also if you can use a manual range scale so your not fighting a scale changing problem. the DVA adapter works ok in most applications but always be aware that the meter is slow to react and may or may not see an intermittant problem. both analog and digital meters have good and bad points. a DVM is much easier for the untrained to use but can give false readings or the readings interpeted wrong. so whichever method you use make sure your methodical and careful and aware of the meters limitations.
R.Johnson
Rodbolt: As I said in my post, I bought the adapter mostly out of curiosity, and the price (35.00), and I have'nt had a whole lot of chance to work with it yet. Have you ever tried your adapter with an analog meter, and how did that work out? I don't know as I'd want the low cost unit for everyday use, but I would think it would work out for the average guy just wanting to pinpoint a dead component.
Mod2
RJ....if you think the tool is worth while and want to post where they can be found, go for it. Just no links please.<br /><br />Thanks....Mod2
R.Johnson
The meter is a Sear's model 82141, The DVA adaper ia a Electronic Specialties model 640. There address is 2449 Pierce Dr. Spring Grove, IL.
rodbolt
R.Johnson<br /> thats actually a nice tool. no experience with that particular meter but the DVA I have owned. I can also tell you it wont swim :) .wont work with an analog meter. as you play with it you will find if it has an ign coil its a usable item. will work on anything with an ign coil to test primary inputs and such. you can even look at how much voltage is actually on the stop circuit if you wish.<br /> its a decent tool at a decent price. I was only trying to point out its limitations and some quirks that are found using a DVA adapter on a DVM.some DVM's react faster than others but most tend to hunt then lock. otherwise the display would change faster than the human eye could follow. for most ops will work great. nice tool at a nice price. doesnt happen often.
farginicehole
Stevens Instruments also makes one called a PVA-1, and it sells for around $45. I'm just trying to learn how to troubleshoot these ignitions (with help from the guys in this forum!) and bought one that I'm using with a Fluke DMM. Stevens also sells an analog DV-77 peak voltmeter, and you can easily find them if you do an internet search.
