I have a 2000 50hp Johnson that won't idle and cuts off when trying to idle. Almost sounds like it is flooding out. Prior work was done because it would not run at anything above idle. Boat shop said VRO pump was problem and put on regular fuel pump. Also, thermostat removed at boat shop recommendation. Did not fix problem and carbs were cleaned and found trash in one. Solved high speed problem, but introduced idle problem. VRO pump was returned to service. Idle problem still exists with new plugs installed.<br /><br />Could it be an undertemp problem since thermostat is out? Or, could it be an air/fuel adjustment problem?
