Re: Yachtwin 4HP Stuck Lower Unit
Hi KC,<br /> Your issue is likely that the driveshaft is stuck in the powerhead. The "long overdue" description only confirms this as your likely problem. Over time the grease that was originally used to prevent the stainless steel driveshaft from making itself one with the steel of the crankshaft can work its way out and lose its effectiveness. Also, it is possible that a previous servicing may have neglected to re-grease the splines, or possibly too check and replace the o-ring that aids in holding the grease in place.<br /> In any case, I would recommend the following - apply gently increasing pressure to pull the driveshaft out of the lower unit, forcing the impeller key past the pump housing. It may leave a small nick in the housing, but won't permanently hurt anything.<br /> Now, you've got a motor with a driveshaft stuck in the powerhead. Using ViceGrips, grab ahold of the driveshaft in a spot that shows no evidence of bearing or seal wear. Better yet, remove the powerhead from the exhaust housing (four bolts at base of lower cowling) and grab ahold of it up above. Leave enough room between the Vice Grips and the powerhead so that you can tap the Vice Grips with a hammer to drive the shaft out of the powerhead. If it doesn't pop out easily, then you may want to use some Kroil or PB Blaster in the stuck area to facilitate removal. <br /> Once you do get it out, clean up the splines - both male and female and inspect them. Often, the rust will degrade the splines to the point where there won't be enough meat to bite into. <br /> For installing the shaft back into the unit, position the unit so that the propshaft points straight down. Usually, this will help position the pinion gear back on center so that the driveshaft will slide in. If not, just pull the rear of the gearcase off and align the gear that way.<br /> For reassembly of the unit back to the motor, be sure to replace the o-ring at the splines, and use a good waterproof grease liberally thumbed into the splines of the driveshaft.<br /> Good luck!<br />- Scott
