John the landlubber
- May 13, 2005
- 146
She turns over, produces spark from both leads, checked gear oil, have trashcan, 24:1 fuel mix, firmly secured on lumber, ordering impeller kit tomorrow. Still have a few questions. Dont know what tubing i need to connect fuel tank to fuel in, and dont want to have to tak engine to shops. can anyone make life easy for me and tell me correct type/diameter internal? Also, the wires from the harness plug socket are not connected to anything, does this matter, doe I have to electric tape them apart or anything? The cover is missing from the right hand side of the leg about half way up, inside it i can see the rod that connects the selector to the gearbox. this appears to have been welded at some stage and although not particularly pretty seems to work ok. does the cover have to be on before starting, no oil in there is there? Any other tips greatly appreciated. cheers!
