Re: no neutral gear
Take the gearcase apart, and remove the oil pump. On the face of the pump is a brass, cup shaped filter screen, rinse, and blow this out. Take the pump apart, and remove the shift piston, or plunger. Carefully polish the piston body with 400 wet, and dry paper. Inside the piston bore there is an O-ring. Remove the O-ring, and carefully polish the bore with 400 paper to remove any burr's, or roughness. Install a new O-ring. When you have the gearcase back together, run a jumper wire from battery (-) to the case. Run a jumper from battery (+) to the green wire. Turn the drive shaft with a speed wrench, or electric drill. The gearcase should shift to neautral. Hook battery (+) to both green, and blue, it should shift to reverse. If everything is correct, it takes very little drive shaft speed to shift. You need the special socket to fit the driveshaft splines for this last test. Your local dealer can get you one. This test will save a lot of time as you don't have to install the case to the engine to test. If everything checks out here, you know your problem is else where.
