Well,I've got a new water pump,housing,and lower unit seals.This beast ran fine and cool for the past month.Now of course,being a holiday weekend with some time off,it's overheating...I've pulled the hose off the starboard cylinder outlet and verified water flow on muffs in the driveway.It's fine.I had to pull that hose to make it back home last time out,so, I figured vernatherm or relief valve,right? No dice.With the hose removed and running in the water,(no muffs)I get very little water out of the thermostat housing.This water is mixed in with slimy exhaust drippings too.I've flushed the water tubes with the garden hose.stuck the hose into the port side water inlet on the head,done most everything I could think of-is it a gasket or seal in the lower unit that is leaking and not allowing the water to make it up into the block??(the reason for the slimy water in the thermo housing??) I've got Seloc manuals,Clymer manuals,and a '72 85 horse 'Rude factory manual-I'm still lost for a cure.Help!!,C.C.
