On my 89 Johnson GT100, which way is the red Run/Manual start fuel seletor suppose to go for run mode, to the right when looking at it from the front of the motor? Also, how many poles should I set my tach too?
The red handle should be pointing toward the body of the primer. I believe that would be to the right as you stated. The tach should be set to "6" for a V4. <br /><br />Where in GA are you located? I'm originally from the GA side. Moved here to be closer to work.
