Re: 86 Evinrude 40hp cutting out on top end??
Sounds to me like you're sucking air between the tank and the fuel pump. Go over every connection point well (disconnect, clean, visually inspect, assemble and tighten clamps). Pay special attention to cracks in the barb fittings from previous overtightening. I recommend OMC clamps and not hose clamps. Also, if your fuel line is a tempo or another aftermarket, deep six it and get an OMC fuel line and bulb. Not sure of the reason but it has solved fuel issues for many in the past.<br />Good luck
