Johnson Steering Problem
Bassderbaiter
I am new to boating in general. I got a 50hp johnson from the 80's for free and I can't use it. I took in in the water and it ran perfect but could not steer. It was locked in place or something. I heard there is a pin or something you have to pull to unlock the steering, but I can't find it anywhere. Does anyone know if it is something simple like a pin, or you think it needs more work after being stored for 4 years. The motor just doesn't turn, even if I push the motor from side to side. PLEASE HELP! I wanna go fishing!
noelm
Re: Johnson Steering Problem
HI<br /> I don't think it will be a 'pin" more than likely steering seized, first disconnect the steering arm to the motor to see if the motor is seized or the cable is jammed, then work from there.
Bassderbaiter
that's what I thought... I will start working on it tonight and let you guys know how it turns out.
