Re: Battery Drain
Well, it takes a pretty good current to draw a charged battery down in just 10 minutes. So, somewhere, something's drawing some serious amperage from your battery, for sure.<br /><br />Aside from the starter, I'm not really sure what could be drawing that much. Is the battery fresh? I suppose it could be a bad battery, but that seems unlikely.<br /><br />The deal is that anything drawing that many amps is going to get warm, unless it's a wire the size of the main battery cable, and even that would get warm after a few minutes.<br /><br />I'd trace all the wiring again and see where your problem is coming from. Start at the console and work back, one wire at a time. Use a DVM or a test lamp and see what wire is getting power that isn't supposed to have power. <br /><br />You'll find it, perhaps from some melted insulation on one of the wires.
