I have A QD-19 10 Hp that has been in the family since it was new. <br />I replace the water pump impeller after checking the operation on a barrel found the dicharge water to be real hot. I may have turned the tips on the impeller in the wrong direction? Will this make a difference in the volume of water pumped. Is it possible to install the impeller wronged.
