50 hp Johnson powered out
max13
I have a 50 hp Johnson that was filled with a 40:1 mix by mistake,then pulled a tube around the lake , now it powers out when leaving the dock and only seems to run half throttle when you floor it. Any ideas guys? Runs well while not in gear, and starts good.
joblo33
Re: 50 hp Johnson powered out
Sounds like either fouled spark plugs or dirty carbs. Start with the easy one, take out your plugs and clean them. A good way of doing this is wipe off the obvious stuff then hold the sparking end over a lighter flame for a minute or so to burn off crud.
Silvertip
40:1 should not have caused this. If plugs are ok, hit the choke/primer momentarily and see if it takes off. If it does, you have a fuel delivery problem. Weak fuel pump, clogged carb(s), air leak etc.
max13
Thanks guys . will start with plugs and work to pump then carb. Hope to post sucess!!
