Re: Hop-up 1961 Evinrude 40 h.p.
Hi OE40,<br /> If your machinist is going to tweak the 35 block, then make sure he does a couple of things. First - don't alter the port timing. That means don't alter the top and bottom reach of the ports. Second, make sure there is a little bit of a chamfer on the port edges so you don't catch a ring on the edge. The best way to open up one of those motors is to square off the ports (vertically) and smooth out the passages leading up to them (intake) and out from them (exhaust) to increase flow. Make sure to leave enough of the webbing between the ports so as to retain the strength of the block. <br /> If you're going to tweak a 35, you can install the 40hp intake manifold and reed plate. I'd also find a later 33hp head which will not have the compression release junk in the dome.<br /> Also, with the 35hp, find an early manual start 25hp flywheel (smooth sides, without a ring gear ) as it is a bit lighter and less likely to snap a crankshaft.<br /> Using a later lower unit will gain you nothing - they're actually heavier and have a larger profile. You can mess around with some old Michigan AJ (Aqua Jet) 2-blade bronze wheels. I think the Michigan Wheel site has some listings for props, even though they no longer carry them. It would give you a search for eBay, etc.<br /> Prop, set-up and hull condition will give you as much or more of a performance boost, for far less invested, than anything you can do to the powerhead(s)....<br /><br />- Scott
