sailor_turned_stinkpotter
- Jan 5, 2003
- 78
I disasembled and cleaned the carb, backed off the idle set screw linkage all the way, set the carb jet screw one and a half turns from fully seated and adjusted the timing so the roller is right on the center of the reference mark with the throttle all the way to slow.<br /><br />But the engine, when started, revs way too high unless I pull the choke out which reduces the revs to about 1200 or so.  If i put the choke back in the engine revs up again.<br /><br />The engine was doing this BEFORE i did any of the above, and nothing i did improved the situation, so now i dont know what to do anymore.<br /><br />Any ideas would be really appreciated.....<br />thanks,<br />dave.
