1986 Evinrude 140 hp<br /><br />Been having stalling problems for some time now. Mostly during acceleration. I've gone through the carbs using aerosol carb cleaner and compressed air several times, installed new carb kits and replaced all the fuel lines right from the tank through to the carbs. I've done a lync and sync, checked compression (120,120,125,130), ensured fresh gas and used a portable tank for testing purposes. Spark is also good.<br /><br />I'm reasonably convinced that I've got an air leak somewhere, most likely in the carbs. What is the best way to track such a thing down? Mist some premix around all each carb (other than in the barrel) and see if the RPMs increase? Would something other than premix be better? I know you aren't supposed to use starter fluid because it has no lubrication, but would it be more appropriate in this situation (used sparsely) for tracking down a possible air leak?<br /><br />Thanks.
