Having trouble with with my motor overheating. Pulled the heads and found head gasket blown. Replaced head gasket and torqued to spec., Changed water pump also, the old water pump looked good but wanted to start fresh. <br />Feeling good that I solved the overheating problems, but now I can't start the motor. Motor turns over, checked spark and sparks appear to be strong, changed out the fuel (thinking it was bad). When the motor turns over it appears it's trying to fire. In fact it will fire enough to disengage the starter. At one point it fired for 1 second, smoked and died. Can't get it to fire any more. Suggestions??
