Re: I think its a 1969 ?
Yup, that's a 1969 40hp Evinrude. A Big Twin, one of the favorite outboards around here. Lots of Big Twin owners on this forum, and lots of help if you're having problems with it.<br /><br />I have a 1958 RDS-20 35hp Johnson. Pretty much the same engine. They made this engine for many years. Parts are relatively available, particularly the commonly-needed ones.<br /><br />Yours is an electric shift model, and that's the only source of worry. If it's not working properly, it can be rather expensive to repair.<br /><br />Some info:<br /><br />Point gap: .020"<br />Spark plug gap: .030<br />Plug type: Champion J4C<br />Fuel:Oil ratio: 50:1<br />Lower unit oil type: BRP Premium Blend. This is important! This lower unit requires a different oil than most outboards. Get it from a Johnnyrude dealer.<br /><br />If you don't know the service history of this outboard, you'll want to replace the water pump impeller, at the very minimum, before putting it into service.<br /><br />If you're going to work on it yourself, you'll need an OEM service manual for it.
