firstboat25
- Sep 2, 2005
- 98
Hope you guys can help me with this<br /><br />What boat does is that when you go to start her up all you do is crank and crank she will try to start but its like there is no fuel reaching carbs<br />I rebuilt them thinking that was there problem put back on and same result nothing.So I took them back off and checked the float needle and saw that it was sticking so I put a drop of oil in and they moved freely.Put carbs back on still same result nothing<br /> So I mixed some gas and oil in a spray bottle and would spray the carbs and get the engine to start up,she would run but die so I would keep spraying the carbs to keep her runnin all of a sudden I noticed that she would stay runnin longer and longer then all of a sudden she would idle pretty good and when she would stall just turn the key and she fired back up thought I was finally making progress<br />WELL I PUT IN GEAR TO CHECK THE LOWER END GAVE HER GAS WAS RUNNING PRETTY GOOD THEN SHE STALLED AND BACK TO SAME PROBLEM <br />DOES NOT WANT TO START WITHOUT THE SPRAY IN CARBS<br />AND WONT STAY RUNNIN EITHER PLUS SHE IS GIVING SOME BACKFIRE <br />Im tired of killin my batteries trying to start this and fix this anyone please help
