I'm new to the board but have researched many many posts here to try to find my problem but I can't narrow down a solution. So here it goes....<br /><br />I have a 1983 75hp Johnson that has trouble starting. I have replaced all coils, rectifier, power-pack and rebuilt the carbs (didn't soak them just blew them out and replaced needle, seat and float). I have spark with a gap of 7/16. It takes a lot to get the motor started. Oh I even set the timing. Once I get the motor started, it stays started but as soon as I shut it off for more than 5 mins or so it difficult to start up again. I have to use the primer and even more so I have to manually use the primer. It's only on start up when I have my problem. I did do a compression check on all three cylinders and all over 100 psi and within 5-8 psi from eachother.<br /><br />Any suggestions? I believe I have a carb problem but the rebuild kit didn't have many part to replace with (It appears it was a rebuild kit that included a few different carbs). Should I soak the carbs in a solution and if so what solution?<br /><br />R/<br />Mike
