Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Just started to tear this engine down and it is good shape. However, I'm looking for a one stop location for gaskets, paint and decals. Also a carb kit would be in order as well. Does anyone target this engine specifically? Thank you.
Hi, thats a pretty old motor. '46-'49 5hp, you might check this web site if he doesn't have it listed contact him and he may be able to locate those parts.<br /><br /> http://www.maxrules.com/fixomcelectricindex.html <br /><br />Mike,
Hi hoho1240, I did a google search and came up with this web site, its loaded with inks, maybe you'll find what you need there.<br /><br /> http://www.vintageoutboard.com/OtherLinks/Links.html <br /><br /><br />GOOD LUCK,<br />Mike
The S/N says it was made in 1948. No differences between '46 and '49 as MCM pointed out, just thought you might like to know.<br />Decals & paint:<br />www.nymarine.ca<br />Decals:<br /> http://www.americanoutboard.com/ <br /><br />Carb kit isn't available, but if you're float is falling apart, there's a merc float that can be made to work.
Thanks fellas.<br /><br />I going to pull the head today to see if the coil and points are in decent shape. Any tricks to this? Like how do I keep the prop from turning when loosing the bolt on the head? Jam it? Clock wise or counter clokwise? Wish me luck.
Hi hobo, Hey that motor's got ten years on me but I found some old posts relating to your motor, there not as old as the motor though but you might find some usefull info.<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi <br /><br />Best of luck,<br />Mike
