another blown head gasket
speed5
hello i have a 91 v4 115 evenrude outboard with a rebuilt power head after about 100 hours i blew a head gasket wha t causes this problem thank you for your help
R.Johnson
Re: another blown head gasket
Was it re-torgued after warm-up, and was it properly sealed from the start?
DHPMARINE
Are you overheating?If so the starboard head usually gets hottest first.<br /><br />DHP
speed5
i retorgued the heads after about 15 hours of break in and i dont think it overheaded because i put a new pump in the same time i changed the power head. how offen aRE YOU SUPPOSED TO RETorgue the heads after you replace a power head
Solittle
I'll bet whoever built the powerhead did not check to see if the heads were warped. Check before you install new gaskets.
