Re: 1969 Evinrude 55HP- Can't get spark-
Yes! Here is another thing to try, disconnect the black, with white stripe wire to the points. With the key on, take this wire coming from the pack, and strike it to ground across the engine block. Each time the wire makes, and breaks contact, the coil shold fire a 3/8 gap, or better. If you have battery voltage on the purple wire to the pack, and the coil does not fire on this test, you have broken it down to the pack, or coil. To test the pack, but a #57, single element 12 volt bulb in series with the green wire from pack to coil, disconnect this wire from the coil, and short the bulb to ground. The bulb should glow when cranking the engine. A #57 bulb would be like a parking lamp from an early auto.
